More economical at high revs with or without VTEC
Didjeridave
For any of us that use the MB6/MC2 on the motorway, having VTEC kick in at the spirited end of motorway speeds must be damn awful for mpg? Is it?? Would a VTEC-disable switch do anything or makes matters worse?
hmm, 70mph doesn't vtec, "slightly more spirited speeds" do appear to. Perhaps I should wire a vtec light in...!
yep that will give you all the info you need ;)
to engage vtec i think you need a throttle position of no less than 50%
OK, I shall rephrase: IF one were to drive at or just over the proposed 80mph top speed in fifth gear, one would be pretty much at the vtec changeover. This will probably make our cars pretty poor on mpg as and when this change occurs. Would disabling vtec help here?
