vtec2011 Posted May 24, 2012 Share Posted May 24, 2012 I have mentioned this in another thread but I made this thread as for what it says on the title..So.. I now have another gearbox and before I fit it on the Civic, I want to make sure the Input Shaft Bearing is good. I don't want to fit it and then find out it has the same problem as the old gearbox. I have checked the input shaft for play but is there any other checks that should be made? And how often does a thrust bearing fail? Because the gearbox already has a thrust bearing fitted but I don't know if its worth fitting a new one. The new gearbox has done 73,000 miles, apparently.. Thanks in anticipation for your help.. Quote Link to comment Share on other sites More sharing options...
Moe Posted May 25, 2012 Share Posted May 25, 2012 listen for any roughness in the isb. for the sake of a few quid just replace the thrust bearing. they are £40 from honda so will be much cheaper from a motorfactor Quote Link to comment Share on other sites More sharing options...
vtec2011 Posted May 28, 2012 Author Share Posted May 28, 2012 listen for any roughness in the isb. for the sake of a few quid just replace the thrust bearing. they are £40 from honda so will be much cheaper from a motorfactorI managed to take the gearbox out. I turned the input shaft/layshaft and it made hell of a noise and it was really slack I fitted the new gearbox, fitted a new thrust bearing and put 2 litres of Honda gearbox oil. Running really smooth and the car feels a lot more responsive (could be my imagination ) and I finally have a really quiet car, chuffed to bits! Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted May 29, 2012 Share Posted May 29, 2012 Good times. Quote Link to comment Share on other sites More sharing options...
