civicturbo79 Posted October 28, 2009 Share Posted October 28, 2009 You can do it with cans, But they just do not have the pressure of a spray gun on a compresser . So bear in mind that finish ill not be 100% as good as a bodyshop finish , But as money at the min is a factor for all of use it will cost a fraction of the cost too. Saying that my company at the min is doing a wheel deal 4 wheels refurbed for £100 all in any colour you want . The only thing im not sure you would get from halfords would be the acid etch primer and the degreaser .But a paint suplier would have the lot in cans or in cans for you to spray with a compresser if you fancy a go. As for coats 1x light coat of acid etch primer (its very thin for spray carfuly for you will get runs).2x coats of primer a light coat and then a coat to cover, you may need 3 coats if it does not cover, Its better to do 3/4 light coats than 2 heavy ones and then get runs . Again 2/3 light coats of your base colour . depends how it covers repeat until you can see no primer. Clear coat is the hard part 1x light coat and then a good coat and then another good coat to get a finish ( no orange peal ).You do not let each coat dry fully between coats as you do with all the other metrials . You just need to let flash off ,so you do not get runs .but its still wet enough to let the coats follow into each other and give you a good finish. Rich. Link to comment Share on other sites More sharing options...
jalesi2001 Posted October 28, 2009 Share Posted October 28, 2009 Sweet, thanks for that Rich!! Link to comment Share on other sites More sharing options...
integraz Posted October 29, 2009 Author Share Posted October 29, 2009 thanks for the help guys! Link to comment Share on other sites More sharing options...
