integraz Posted October 26, 2009 Share Posted October 26, 2009 guys need help want to respray my speedlines again cause the guy who did them did a cowboy job,so what would a need to do.il put a pic up tomoz of the alloys! Link to comment Share on other sites More sharing options...
civicturbo79 Posted October 26, 2009 Share Posted October 26, 2009 1. start by getting the tyres removed2.paint stripper the wheels3 sand down any areas of paint that are left with some 320 grit paper. 4 red scotch pad the hole wheel to key up and clean the surface 5. pre clean the wheel to clean and de grease the wheel 6. acid etch primier the wheel .7. primier the wheel (wet flat with 800 grit paper if there are bits in it )8. spray on your base coat colour .9. spray on your clear coat.(Leave paint and primiers to dry properly between coats . )job doneRich. Link to comment Share on other sites More sharing options...
Dave Posted October 27, 2009 Share Posted October 27, 2009 Nice one Rich Link to comment Share on other sites More sharing options...
integraz Posted October 27, 2009 Author Share Posted October 27, 2009 cheers mate. Link to comment Share on other sites More sharing options...
integraz Posted October 28, 2009 Author Share Posted October 28, 2009 just been told by my mate that you dnt need to sand it down??? Link to comment Share on other sites More sharing options...
ShortySco Posted October 28, 2009 Share Posted October 28, 2009 I'd say that saying you don't 'need' to sand it down is right enough.But if you want the best job, it's essential, it gives the surface a roughness for the next coat bond to, rather than painting onto a smooth surface, which will lead to a much more flawed and easily chipped finish.I often hear people say things like "90% of the work is in the preparation"That said i'm no expert, but I did once work in the paint department at B&Q Link to comment Share on other sites More sharing options...
civicturbo79 Posted October 28, 2009 Share Posted October 28, 2009 90 % of the job is the prep ,i have worked in bodyshop now for 14 years now . If you do not sand the wheels the paint will not stick to the surface that is already there . Buy stripping the wheels and starting from clean metal ,there is nothing for the new paint to react with . For a mint job follow my guild . Rich. Link to comment Share on other sites More sharing options...
southwestmb6 Posted October 28, 2009 Share Posted October 28, 2009 Riche is 100% right as i have worked in bodyshop for 16 years. Follow his instructions . (at your own risk if you dont )There is always powder coating dont forget. Link to comment Share on other sites More sharing options...
civicboy Posted October 28, 2009 Share Posted October 28, 2009 also dont let a noddy of a mechanic play a practical joke on ure alloys aswell trust i should know on that onehttp://civic5.com/forum/viewtopic.php?f=37&t=1091 Link to comment Share on other sites More sharing options...
jalesi2001 Posted October 28, 2009 Share Posted October 28, 2009 1. start by getting the tyres removed2.paint stripper the wheels3 sand down any areas of paint that are left with some 320 grit paper. 4 red scotch pad the hole wheel to key up and clean the surface 5. pre clean the wheel to clean and de grease the wheel 6. acid etch primier the wheel .7. primier the wheel (wet flat with 800 grit paper if there are bits in it )8. spray on your base coat colour .9. spray on your clear coat.(Leave paint and primiers to dry properly between coats . )job doneRich.How many coats of the primer, paint and clearcoat do you rekon Rich? And is rattle cans ok, or not even worth bothering with? Can you get all the stuff from somewhere like Halfrauds, or a specialist paint shop? Hopefully im not the only one wanting to know the answer to these questions!!!!! Link to comment Share on other sites More sharing options...
