andrew1 Posted June 10, 2012 Share Posted June 10, 2012 Hi guys need some advice/help again Last night whilst driving i noticed a lot of excessive clutch play on the clutch pedal and very soft when depressed (like nothing there)I also noticed that every now and then it struggled a bit to go into gear now i know there is nothing wrong with the clutch itself no slipping it has a judder on pull off but that's the rear mounting, I opened the bonnet and had a look this morning i noticed the reservoir is empty also on the clutch release cylinder is wet so does it need a complete new one or just a kit installed?? it looks very rusted so i was thinking along the lines of pitting inside the bore itself. Where would you suggest i get the parts or unit from as my motor factor always gets the wrong parts If a new one is required will this be ok ?( Ebay Item number: 300715118337 )Once again thanks Quote Link to comment Share on other sites More sharing options...
noodels Posted June 10, 2012 Share Posted June 10, 2012 looks fine can compare with slightly better£s one >>herehttp://www.japarts.co.uk/shop/index.php ... search&s=0 Quote Link to comment Share on other sites More sharing options...
james Posted June 10, 2012 Share Posted June 10, 2012 dude you should be ashamed of yourself that fluid is just dirt =/go to your local motor factors and get one + new fluid Quote Link to comment Share on other sites More sharing options...
noodels Posted June 10, 2012 Share Posted June 10, 2012 top up and bleed that will last few miles until new one arrives Quote Link to comment Share on other sites More sharing options...
andrew1 Posted June 10, 2012 Author Share Posted June 10, 2012 Thanks for that. I will get a new one tomorrow Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted June 10, 2012 Share Posted June 10, 2012 top up and bleed that will last few miles until new one arrives Check for leaks while doing this. Quote Link to comment Share on other sites More sharing options...
