EmZvr Posted July 20, 2012 Author Share Posted July 20, 2012 do you realy need to upgrade from normal ??Good question The front discs had a ~ 2 - 3mm edge so they had to be changed but the rear ones were perfect. I changed them because I wanted everything to be new. The worst part is I gave them away almost for free. Quote Link to comment Share on other sites More sharing options...
Emin89 Posted October 21, 2012 Share Posted October 21, 2012 Ive got a strange noise from the rear right, a kind of "vibrating squeak" when I first take off, sounds like a bus for a second, then goes away, after a drive when I got home I put my hand on the wheel, but it isnt hot. I also noticed the handbrake holds only the rear right wheel, I tried adjusting the cable, but It just oscilated away from the left side, as if it would be tight. Have you some expirience with a faulty/sticking brake pads? I hope its a little bit of rust on the pads sliding points, because I dont feel like replacing the pistons/calipers Quote Link to comment Share on other sites More sharing options...
knight Posted October 21, 2012 Share Posted October 21, 2012 Ive got a strange noise from the rear right, a kind of "vibrating squeak" when I first take off, sounds like a bus for a second, then goes away, after a drive when I got home I put my hand on the wheel, but it isnt hot. I also noticed the handbrake holds only the rear right wheel, I tried adjusting the cable, but It just oscilated away from the left side, as if it would be tight. Have you some expirience with a faulty/sticking brake pads? I hope its a little bit of rust on the pads sliding points, because I dont feel like replacing the pistons/calipers New caliper mate will sort that! mine has done the same TWICE to me! Quote Link to comment Share on other sites More sharing options...
Emin89 Posted October 21, 2012 Share Posted October 21, 2012 Damn it! I was hoping not to hear that Wont make much sense buying second hand onesOh well, need to scrape some cash together thx for the infoEDIT: €93 new, each Quote Link to comment Share on other sites More sharing options...
