Intermittent Running Problems with the MB6! :(
Soldier456
check your injectors, had similar prob on my deck, tried everything dizzy, plugs and leads, turned out it was one of the injectors, all i done was unpluged it and pluged it back in and hey presto problem sorted!!
  • 2 weeks later...
have you tried testing the coil and igniter, the coil can go which is inside the dizzy unit. first thing though is check all the ignition relays and fuses next to the battery and under the steering column
Guest johnbankshonda
  Soldier456 said:
So... Got hold of another Dizzy from a running civic... Still wont start?! STILL NO SPARK?! Power going to the dizzy... What now? Main Relay?
Sent you a pm :)
+1
As I said, this is a dizzy off a happily RUNNING civic. The Dizzy is not at fault, so no point in testing coil or ignitor... Gana test for a triggering signal next from the plugs. I might need to test ignition sensors like TDC sensor, crank etc. Any info on these sensors would really help! Cheers guys.
