xxlukexx Posted November 2, 2009 Share Posted November 2, 2009 Hi all,Recently noticed that my brake lights are both not working, but the spoiler brake light is. I tried changing the bulbs and they still don't work, so I'm assuming this is a fuse or a relay. But it seems weird that the spoiler light would be on a different fuse to the other lights.Anyone got any idea what could be causing this?Cheers,Luke Link to comment Share on other sites More sharing options...
Guest Posted January 18, 2010 Share Posted January 18, 2010 Hi Probably bad placement of bulbs it already happened with me. To take doubts put a multimeter and see if it have voltage thereSee ya Link to comment Share on other sites More sharing options...
jalesi2001 Posted January 18, 2010 Share Posted January 18, 2010 It wont be a fuse or relay bud if the spoiler lights works, that also rules out the brake light switch too. Do your rear sidelights work? Have you got the correct bulbs fitted and fitted round the right way? Get some pics up if you can!! Link to comment Share on other sites More sharing options...
L30TSE Posted March 30, 2010 Share Posted March 30, 2010 As Jalesi said, it's the bulbs. Try some different bulbs. I've had several new bulbs which were duds! Link to comment Share on other sites More sharing options...
MBBREAKERS Posted March 30, 2010 Share Posted March 30, 2010 some times different stop and tail lights have the pins on the sides different ways around , so wrong pin arrange ment could stop blub going in correct Link to comment Share on other sites More sharing options...
jamezzz Posted April 24, 2014 Share Posted April 24, 2014 I have this same problem. My spoiler brake light always works. Sometimes the brake lights in the rear clusters work, sometimes just one side will work and other times both sides don't work. I swapped out both the bulb holders and wiring harnesses from my old Aerodeck before I scrapped it. Same thing! Aghhh! Any clues? From what I have read above, it won't be a dodgy switch at the brake pedal if the spoiler light works correctly? Please help. MOT is in August so I have some time thankfully! Link to comment Share on other sites More sharing options...
Krzys Posted April 24, 2014 Share Posted April 24, 2014 You'll have to get a multimeter out and see what's happening mate! Link to comment Share on other sites More sharing options...
