brakes help!!
JORDEN_MB6
hi, my old brakes on my mb6 were warped and vibrating the car terribly, but couldnt find any noticeable change in disc warpage, i recently purchased a set of drilled and grooved discs all aqround and run them in properly, for 400 miles with hardly any pedal pressure and they were fine but now the problem has come back as vibrations and constant squealing of the front discs, would it be another set of warped discs or is there any other problem that would cause this
i am quite upset as these were £200 brakes and i cant see any disc marks or anything but there vibrating, could anyone help please! thanks
i got new brakes and under heavy braking my front left vibrates. figure that one has not bedded in properly. a quick skim im afraid. your pads should slide in and out with 2 fingers when installing. may get rid of the squealing. also which shims did you use?
