JORDEN_MB6 Posted August 6, 2012 Share Posted August 6, 2012 hi, my old brakes on my mb6 were warped and vibrating the car terribly, but couldnt find any noticeable change in disc warpage, i recently purchased a set of drilled and grooved discs all aqround and run them in properly, for 400 miles with hardly any pedal pressure and they were fine but now the problem has come back as vibrations and constant squealing of the front discs, would it be another set of warped discs or is there any other problem that would cause this i am quite upset as these were £200 brakes and i cant see any disc marks or anything but there vibrating, could anyone help please! thanks Quote Link to comment Share on other sites More sharing options...
weetec Posted August 6, 2012 Share Posted August 6, 2012 i got new brakes and under heavy braking my front left vibrates. figure that one has not bedded in properly. a quick skim im afraid. your pads should slide in and out with 2 fingers when installing. may get rid of the squealing. also which shims did you use? Quote Link to comment Share on other sites More sharing options...
JORDEN_MB6 Posted August 6, 2012 Author Share Posted August 6, 2012 erm shims, my previous set didnt have any and my current set do no have a set of shims in, do i need some as the whole set did not come with any shims. also where can you get these skimmed and how much was it to do the skimming? Quote Link to comment Share on other sites More sharing options...
