aerodeckcrewser Posted February 9, 2014 Share Posted February 9, 2014 Any update or did you give up? I've seen the k line wire on the 5 pin does not line up to the correct pins through the 5pin to 16 pin wire and then the pin is again different on the elm so you have to do a bit of chopping :-B Quote Link to comment Share on other sites More sharing options...
xchipx Posted August 15, 2014 Share Posted August 15, 2014 Bumping a thread sorry but is there any update to this? Has anyone got the ecu talking yet?On cars that have the 5pin connector are the adapters working ? Quote Link to comment Share on other sites More sharing options...
aerodeckcrewser Posted August 15, 2014 Share Posted August 15, 2014 It does not work you need full obd2 these vehicle are obd2a the ecu does not send the correct signals through to the 3 pin out to 5 pin etc Ecu is basically obd2 but wiring is obd1 hence obd2a half way in why if you want to fit an obd1 ecu it fits by just shaving the plug,Only way around it all is if you are using a p28 or p30 ecu for remap purposes etcThere is a 5 pin data port you have to remove the solder and wire to an ostrich unit or equivalent then from the ostrich to laptop thats as good as it gets.Or buy a full obd2 car that has 5 pin plug ready.They sell these conversion leads as they work in the usa models obd2a but not europe. Quote Link to comment Share on other sites More sharing options...
aerodeckcrewser Posted August 15, 2014 Share Posted August 15, 2014 When i say 5 pin i mean 16 pin sorry for the confusion Quote Link to comment Share on other sites More sharing options...
xchipx Posted August 17, 2014 Share Posted August 17, 2014 Really appreciate your comments etc, but get this, ive actually located a full size obd2b connector on the mb2 and torque worked instantly :/I was mistaking the abs connector {next to the 2 pin service connector } for the diag connector. I must have a really late model 1.4i mb2 for it to work? My car sure is a strange one, I cant find a rear wheel bearing anywhere and neither can the motorfactors, none fit so far. Quote Link to comment Share on other sites More sharing options...
aerodeckcrewser Posted August 17, 2014 Share Posted August 17, 2014 Yeah deffo a late model and is it disc? Quote Link to comment Share on other sites More sharing options...
xchipx Posted August 17, 2014 Share Posted August 17, 2014 Nope drum brakes non abs non sunroof but does have half leather interior :/ Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted August 17, 2014 Share Posted August 17, 2014 Someone on here has this working also i can't remember who. Someone had a blue tooth adapter sticking out side of center console. I questioned it and they got an obd2 port there. @Chandler maybe? Oh i Can't remember Quote Link to comment Share on other sites More sharing options...
xchipx Posted August 18, 2014 Share Posted August 18, 2014 Yeah thats where my connector is.Took out the ecu today, according to pgmfi its actually running as an obd1 ecu { the code on the ecu is pj1 } and is mapable. However I have now taken the actual ecu apart and it doesnt have any options to socket it so must be a different / later version of the p1j found below. See here :http://wikitest.pgmfi.org/twiki/bin/view.pl/Library/P1J ps : It has a obd2A harness to the ecu. Quote Link to comment Share on other sites More sharing options...
aerodeckcrewser Posted August 18, 2014 Share Posted August 18, 2014 But the ecu is obd2 the reverse to the earlier models ha ha typical. Not worth the hassle anyway if you ask me rather just hook dials up and see my readings and use my paper clip to count error readings lol 1 Quote Link to comment Share on other sites More sharing options...
