E=MC2 Posted November 14, 2012 Share Posted November 14, 2012 can i use friends Rover 420 diesel chasis number to order right rear ARB drop link?ARB looks preety much as ZS's one, but please confirm it if anyone can Quote Link to comment Share on other sites More sharing options...
noodels Posted November 14, 2012 Share Posted November 14, 2012 look on this link, can get bush there too http://www.rimmerbros.co.uk/Item--i-GRID003099 Quote Link to comment Share on other sites More sharing options...
E=MC2 Posted November 14, 2012 Author Share Posted November 14, 2012 this is drop linkas you can see, LAC mounting point bush is in metal shell, so it cannot be removed from link. Or i dont know ho to remove it. Quote Link to comment Share on other sites More sharing options...
E=MC2 Posted November 29, 2012 Author Share Posted November 29, 2012 eurekathis is civic 4th gen sway bardrop link looks pretty much the same as MG's one, but ill like to know are they same lenght and mounting points Quote Link to comment Share on other sites More sharing options...
Karjis Posted January 7, 2013 Share Posted January 7, 2013 Well, MG ZS is basically Rover 400 and both share most of chassis with M:s so.. Rover part is just right. 4th gen Honda parts aren't the same. Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted January 7, 2013 Share Posted January 7, 2013 Yeah drop links are the same on numerous old Honda's and rovers.Try rimmer bros website. Just click through to find car, bushes and droplinks are real cheap.if you've already got the metal part bet the bushes can be bought go a fiver. Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted January 7, 2013 Share Posted January 7, 2013 That bush will come out easy if its old. The metal tube will break free then the rubber will come out.to get new ones in I found awkward at first. Until you know how.Bit of grease on bush, using a vice just press new bush in. Push on the metal tube with vice and it'll pop in easy.Whatever you do don't put a socket over and push the rubber. It doesn't work I tries for hours. Quote Link to comment Share on other sites More sharing options...
noodels Posted January 8, 2013 Share Posted January 8, 2013 look on this link, can get bush there too http://www.rimmerbros.co.uk/Item--i-GRID003099^^ Quote Link to comment Share on other sites More sharing options...
E=MC2 Posted January 9, 2013 Author Share Posted January 9, 2013 rimmer is over 1300 miles far from me , i would like to find it somewhere closertoday i will get the price for civic 4th gen drop link and bush if it's the same as MG's one, but i am still concered on pressing out the metal tube (filled with bush rubber) which ends are wider then drop links hole so i don see how it will come outi dont know is the metal tube made from 2 halves or is it one piece? If it is one solid part, it wont come out because of upper mentioned wider endswhat i know that metal tube have free space in drop links hole and make annoying tok-tok sound Quote Link to comment Share on other sites More sharing options...
E=MC2 Posted January 9, 2013 Author Share Posted January 9, 2013 hondas bushing only as original part, and it is more expencive than whole link tommorow i call someone for rover parts Quote Link to comment Share on other sites More sharing options...
