burbleboy Posted November 19, 2012 Share Posted November 19, 2012 Hi troops,My drivers front window stuck down, so i removed the regulator and jammed window up as a temporary repair.Guys in my work fed power to the regulator and it went up and down.I ordered a 2nd hand door switch off ebay and connected it up along with the regulator (didnt re-fit...just in case). The regulator goes down but won't go up. I can hear the door control box clicking away when switch activated up and down.Any ideas please?RegardsAlastair Quote Link to comment Share on other sites More sharing options...
burbleboy Posted November 20, 2012 Author Share Posted November 20, 2012 UnicyclingTom said: Have you tried the regulator with weight on it?Hi there,Yes, mechanic put some weight on it and regulator moved ok, no noises or anything.I had a go at wire testing and fuse is ok.The regulator goes down when door switch and regulator re-connected, so that would make the regulator ok, if it was goosed then the regulator would not move at all. Must be a feed problem?cheersalastair Quote Link to comment Share on other sites More sharing options...
burbleboy Posted November 22, 2012 Author Share Posted November 22, 2012 Turns out its the door control unit that had burn out! Electrician in my work tried to solder it but it was beyond repair. Got free control unit from guy in my work that scrapped a vti on a while ago...result! Quote Link to comment Share on other sites More sharing options...
simpo Posted November 22, 2012 Share Posted November 22, 2012 Was about to say that mine did the same but got away with a bit of solder Quote Link to comment Share on other sites More sharing options...
