crazyrob9999 Posted November 20, 2012 Share Posted November 20, 2012 Hey guys wandering if any of you can help.Doing an engine swap in my mb2 now been reading up about it and loads of people have said you need key and immobilizer box when you do it.Now I not sure I will have that when get engine so my question is when I plug it all in will the immobilizer stop me from starting the engine?If so is there a way to bypass or deactivate the immobilizer or can an auto electrician do this?Or is there a way to reset all the immobilizer so it will all work with each other?Cheers Quote Link to comment Share on other sites More sharing options...
spud Posted November 20, 2012 Share Posted November 20, 2012 Think one of the only ways is a different ecu with immobilser delete? Might be wrong though Quote Link to comment Share on other sites More sharing options...
knight Posted November 20, 2012 Share Posted November 20, 2012 what engine you putting in??? Quote Link to comment Share on other sites More sharing options...
FREAKBOY Posted November 20, 2012 Share Posted November 20, 2012 If you are not changing the ECU or the ignition lock/key then the car will be unaffected and should start. If you are doing an OBD1 swap from OBD2 you will also be OK. If you are changing the ECU from OBD1 to OBD2 or OBD2 to OBD2 or later then you will need to either remove the IMMO chip from the ECU, swap the IMMO chip for the right one or get it all re-coded. Doctronic also do something to bypass it I think.The engine itself has nothing to do with the immobiliser Quote Link to comment Share on other sites More sharing options...
crazyrob9999 Posted November 20, 2012 Author Share Posted November 20, 2012 Cool well I putting a b16 in where a d14 was so am changing the ecu but was only wandering if the immobilizer would stop it and if an auto electrician would beable to sort this Quote Link to comment Share on other sites More sharing options...
simpo Posted November 20, 2012 Share Posted November 20, 2012 B16 out of what? Also what ecu are you running Quote Link to comment Share on other sites More sharing options...
crazyrob9999 Posted November 20, 2012 Author Share Posted November 20, 2012 Ek4 civic and as far as I'm aware it the standard ecu to the engine Quote Link to comment Share on other sites More sharing options...
FREAKBOY Posted November 20, 2012 Share Posted November 20, 2012 Your ECU won't run the B16 properly even if it fires up. You will need the ECU,keys and ignition barrel from the donor car OR do an OBD swap and run a P28 with a tune. You might also need a bit of wiring in there for the extra bits on a B series like the Vtec Quote Link to comment Share on other sites More sharing options...
simpo Posted November 21, 2012 Share Posted November 21, 2012 How much you pay for the engine? Also have a look on h-tune he might be able to help you out Quote Link to comment Share on other sites More sharing options...
crazyrob9999 Posted November 21, 2012 Author Share Posted November 21, 2012 500 for everything and yeah a few people have mentioned them will give them a go cheers Quote Link to comment Share on other sites More sharing options...
