door change - electrics
p-con_91
Hi guys
Bought a vti-s couple months ago and looking to replace n/s back door. Had a look at it and wondered about electrics (central locking) - will it still work on the new door? There seems to be a little 3-pin plug in a rubber casing in the new door-jam, so just want to check that's all I need to connect up for it to work.
Sorry for my ignorance, I don't do diy but this looks like it should be easy ;)
Also other back door central locking doesn't work - any ideas? Other electrics in the back work fine (for now!)
Right, excellent. No excuse now then, except it's cold out there!
Thanks
u got easy if its just cold
a little snow in brighton and the whole damn town has come to a standstill
buses are cancelled but the bus company says "the snow is not thick enough to enable use to operate snow chains safely..." thats a load of BS, the friday feeling had got the better of them...
Any tips on releasing the plug from the door socket - looks like there's a catch on inside of socket that's stopping me atm.
Did you have this problem?
i just pulled the plug rubber back and push the top and bottem together and they just popped off! WACK11111
