Nasty knocking from drivers side rear
ramy
Hi all I have a poorly aerodeck , it's developed a nasty metallic like knocking from rear drivers side , when driving if I go over bumps grids etc i get the knocking , you can hear it from outside as we'll as in the car , please help , can't get to mechanic till Tuesday , could it be a worn bush or worse a failed shocker , bit gutted as only had mot in jan n passed with no advisors :/
Thanks in advance ramy :)
What could be causing the knocking then , I'm worried it may be a failed shock n cost a fortune , but if I park up n rock the car there is no knocking and damping is fine , only knocks when travelling :/
Check its not being caused by loose items in the boot or spare wheel well. Could also be rear doors or tailgate loose on the locks/ loose brake shield/ loose shock top mounts. Most likely candidate is the trailing arm bush- usually more of a dull thud than a metallic sound, easy to check visually. Otherwise knackered bush on the lower control arm (probably shock mount).
Hi i had my deck in garage today had all bushes n mounts and exhaust n mounts checked and everything was spot on :S but the knocking is still thete , mechanic said it sounds more like loose exhaust baffles but exhaust is fine , he said last guess would be top mount on rear shock , can you tell me how i access it so can check it out please
Thanks ramy
