Damo96 Posted February 28, 2013 Share Posted February 28, 2013 Right I've got a little 1.4 mb2 civic and I would like to do some modifications. Coilovers, I have read that the ebay ones will fit fine with minor modification. Exhaust, I'd like a 3-3.5'' back box which are hard to find, maybe an mb6 one may fit? Wheels, as it is only a 1.4 I'm looking for a set of 15'' multispoke alloys for less than £350 in good condition? If anyone knows any cheap worth while performance modifications which I can do then please tell me, and will the vti-s lip kit and boot spoiler fit straight on? what is needed? Cheers! Quote Link to comment Share on other sites More sharing options...
kyekye09 Posted February 28, 2013 Share Posted February 28, 2013 for the lip kit you will need the fitting kit the spoiler should fit straight on but you will need to drill into the boot performace mods vtec mini me(you can get a d16 vtec head real cheap) then its breather mods induction kit or kand n drop in filter exhaust manifold decat or high flow cat 2" exhaust system should sort you out Quote Link to comment Share on other sites More sharing options...
Damo96 Posted February 28, 2013 Author Share Posted February 28, 2013 Will a mb6 catback fit on my mb2? Quote Link to comment Share on other sites More sharing options...
kyekye09 Posted February 28, 2013 Share Posted February 28, 2013 if you get the right size of cat or ajustable decat as the mb6/mc2 cats are around 485mm where as our baby d series motors only have 420mm and you dont want the diameter of your piping to be to big as you will loose performance?(ive got 58mm from manifold collector to the inlet of my rear box but i have a fair few supporting mods to justify that size) so watch when picking an exhaust forto big a bore but all hangers are in the same place if that helps Quote Link to comment Share on other sites More sharing options...
Damo96 Posted February 28, 2013 Author Share Posted February 28, 2013 If I was to buy an aftermarket back box, what would be the maximum tip size I'd want? Or any idea where I could pick up a full aftermarket exhaust system, as in manifold to the back box? Quote Link to comment Share on other sites More sharing options...
kyekye09 Posted February 28, 2013 Share Posted February 28, 2013 there are loads of manifolds on ebay for not alot of £'sss with having a small standard motor id go with a 4-2-1 with 2" collector near enough all civics from 92-2000 mid sections are the same.. again id go with 2" as for the back box i went for a custom as you get to pick the sound and tip..... tip size is not important you could go for jap style 4-1/2" if you wanted that sort of style Quote Link to comment Share on other sites More sharing options...
Damo96 Posted February 28, 2013 Author Share Posted February 28, 2013 Ah alright cheers! They all say that they won't fit on eBay! Also what is a reasonable height to lower the mb's that isn't so low that if scrapes on speed humps and pavements? If anyone has any images of their lowered mb please post them! Quote Link to comment Share on other sites More sharing options...
Damo96 Posted February 28, 2013 Author Share Posted February 28, 2013 Looks quite good, But as I'm fitting 15 inch alloys Mine would sit differently! Quote Link to comment Share on other sites More sharing options...
Damo96 Posted February 28, 2013 Author Share Posted February 28, 2013 No, could you send me a link please as can't find it! :/ Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted February 28, 2013 Share Posted February 28, 2013 This is mine on 15's lowered 55mm, doesn't scrape, well not much anyway It's better on the 16's in my sig pic. Quote Link to comment Share on other sites More sharing options...
