knight Posted March 9, 2013 Share Posted March 9, 2013 Thanks for the constructive posts so far lads Any chance an Integra distributor is the same?http://www.ebay.co.uk/itm/Integra-Civic ... 5653808d4cI've heard from peeps that all b16's & b18 use the same dizzy just some are with different plugs obd1 & obd2 (early and late spec) So make sure the plug are the same otherwise you be cutting wires etc Quote Link to comment Share on other sites More sharing options...
Raz s Posted April 3, 2013 Share Posted April 3, 2013 Before spending big bucks id check all the earth points round the bay. I once did a clutch on a punto for a freind. It drove fine until it hit any slight bump then it would cut out. It turned out to be the main earth on the box that wasn't tight. Like i said its just worth checking before you go spending money. Quote Link to comment Share on other sites More sharing options...
Paulvti Posted June 21, 2013 Share Posted June 21, 2013 I'd put my money on the distributor mate I've gone through no end of them on my 1990 Crx and have have all the different sort of issues, this being one of them!Stick with obd2 as they are the most reliable out of all, and the plugs would be different on other Hondas of different years and types, yes the integra on would fit Quote Link to comment Share on other sites More sharing options...
