weetec Posted December 10, 2009 Share Posted December 10, 2009 i have bought a set of speedline mistral 2 alloys and wanted to know if they will fit my mb6. im a bit confused with caliper clearance as i know it can be a issue, also the bumf i read up with regards to other things such as width.[attachment=0]GetAttachment[1].jpg[/attachment]. these alloys are 4x114.3 ET35 7.5x16H2. speedline mistral 2 model no SL766 would they fit, any help appreciated. Link to comment Share on other sites More sharing options...
FlunkyVTEC Posted December 10, 2009 Share Posted December 10, 2009 PCD wise they should fit, as for caliper clearance, there is one way to find out. This can be a tricky subject as it depends on several things such as the actual wheel design. ET wise they might be on the low side. 35 will dramatically change the handling of the car according to anything I've read about the subject until now. Link to comment Share on other sites More sharing options...
Guest paul-mb6 Posted December 10, 2009 Share Posted December 10, 2009 i doubt you'll have caliper clearance issues with them wheels but wheel arch clearance will probably be a problem with a 7.5" wheel and a 35mm offset if you've lowered the car. i'm running et 35 with a 7" width rim and the arch clearance is very small so you may end up needing the wheel arch lip rolled to avoid rubbing Link to comment Share on other sites More sharing options...
weetec Posted December 13, 2009 Author Share Posted December 13, 2009 thank you, were going for it, keep you posted with results. Link to comment Share on other sites More sharing options...
weetec Posted December 29, 2009 Author Share Posted December 29, 2009 pictures posted! Link to comment Share on other sites More sharing options...
jalesi2001 Posted December 29, 2009 Share Posted December 29, 2009 Where?!! Link to comment Share on other sites More sharing options...
weetec Posted December 29, 2009 Author Share Posted December 29, 2009 look under chassis ,suspension etc..the following title.. alloys 7.5 wide offset et35 pictures Link to comment Share on other sites More sharing options...
