Guest Posted December 15, 2009 Share Posted December 15, 2009 engine fan fails to come on. relaced the relay but to no avail.any ideas? Link to comment Share on other sites More sharing options...
civicturbo79 Posted December 15, 2009 Share Posted December 15, 2009 There is fuse for it in the engine bay fuse box in the top right hand corner as you look at the engine . Rich. Link to comment Share on other sites More sharing options...
Guest Posted December 15, 2009 Share Posted December 15, 2009 big yellow thing? Link to comment Share on other sites More sharing options...
civicturbo79 Posted December 15, 2009 Share Posted December 15, 2009 There is just a black fuse box in the corner pop the lid off and there are a few fuses in there just see if one is blown . Rich. Link to comment Share on other sites More sharing options...
jalesi2001 Posted December 15, 2009 Share Posted December 15, 2009 Or your fan switch is broke, its on your thermostat housing iirc. I take it your car is warming up ok, and the temp gauge is going to half way?? Link to comment Share on other sites More sharing options...
Guest Posted December 15, 2009 Share Posted December 15, 2009 yeh it warms up ok, temp rises half way but after driving it overheats at idle and the fan doesnt kick in. is that the sensor on the thermostat that looks similar to a lamda? Link to comment Share on other sites More sharing options...
jalesi2001 Posted December 15, 2009 Share Posted December 15, 2009 umm, i suppose it sort of looks like a lamda sensor, but no where near as long!! Its a small-ish shortish 2 pin sensor iirc, and sits facing down on the thermostat housing. (back left corner of engine as you lean over the bonnet looking at it!!). Link to comment Share on other sites More sharing options...
Guest Posted December 16, 2009 Share Posted December 16, 2009 ok ill have a bash at sorting that. Link to comment Share on other sites More sharing options...
Guest Posted December 17, 2009 Share Posted December 17, 2009 not the relay and not the fuse so must be the sensor. Link to comment Share on other sites More sharing options...
lacos Posted December 17, 2009 Share Posted December 17, 2009 you say its over heating when it does this check the top hose is getting hot the one that comes from the top of the rad to the thermostat housing if its not your thermostat is stuck in the closed position replace it if this is not the problem then i reckon its the sensor ok mate Link to comment Share on other sites More sharing options...
