Guest Posted December 17, 2009 Share Posted December 17, 2009 cheers Link to comment Share on other sites More sharing options...
Guest Posted December 18, 2009 Share Posted December 18, 2009 update - fan now works when its supposed to but still overheats slowly? im starting to think its more serious than i thought now. Link to comment Share on other sites More sharing options...
civicturbo79 Posted December 18, 2009 Share Posted December 18, 2009 When does it over heat when you are driving it hard . is it losing water . if so head gasket . Rich. Link to comment Share on other sites More sharing options...
Guest Posted December 18, 2009 Share Posted December 18, 2009 no it over heats after its heated as normal then left to idle. not losing any water and theres no bubbles coming up through the coolent when i remove the rad cap and start the car. Link to comment Share on other sites More sharing options...
civicturbo79 Posted December 19, 2009 Share Posted December 19, 2009 Its so hard to pin point problems with out seeing the car , if the fan is coming on and its still over heating go for a new thermostat first . As it could not be opening fully and thats why its over heating . if thats does not do it i would be back to the headgasket . Rich. Link to comment Share on other sites More sharing options...
jalesi2001 Posted December 19, 2009 Share Posted December 19, 2009 Water pump fan blades??????? Uber rare but not unheard of..... If the water pump wasnt circulating the coolant efficiently that would cause overheating. Its probably not, but bear it in mind!! Link to comment Share on other sites More sharing options...
