fyfie5 Posted June 18, 2013 Share Posted June 18, 2013 when i decatted my car the light came on so i got a sensor spacer off of ebay for like a 5er and it spaces the sensor away from the fast flowing gasses and the car thinks the cat is still on and the light went away have to say sometimes the light pops on but soon goes off again. Quote Link to comment Share on other sites More sharing options...
fyfie5 Posted June 18, 2013 Share Posted June 18, 2013 and if you need a new sensor get one off a car that breaking i got one for £12! oem aswell! Quote Link to comment Share on other sites More sharing options...
Chandler Posted June 18, 2013 Author Share Posted June 18, 2013 ok i'll try a sensor spacer for now and see what happens Quote Link to comment Share on other sites More sharing options...
Didjeridave Posted June 18, 2013 Share Posted June 18, 2013 Sensor spacers are for dual sensor setups with a second sensor downstream of the cat. MB/Cs have one pre-cat sensor & use this in closed circuit to set the fuelling. A one sensor system 'has no idea' that a cat is fitted, the cat just reduces emissions whatever's chucked through it. An extender will exacerbate the incorrect reading problem.Best of luck with it Quote Link to comment Share on other sites More sharing options...
Chandler Posted June 18, 2013 Author Share Posted June 18, 2013 cheers mate ye i've got one on the manifold as you would normally have, but its on the lower pipe where they join rather than just on 1 port. then obviously one on the Decat. will be hunting for a spacer tonight Quote Link to comment Share on other sites More sharing options...
Didjeridave Posted June 18, 2013 Share Posted June 18, 2013 Sorry, but can I check what car you are fitting this to? MC1 as per your stats? Quote Link to comment Share on other sites More sharing options...
Chandler Posted June 18, 2013 Author Share Posted June 18, 2013 ye MC1 mate Quote Link to comment Share on other sites More sharing options...
Didjeridave Posted June 19, 2013 Share Posted June 19, 2013 ...ah! You're obd2 then, all makes sense! Hope it works out Quote Link to comment Share on other sites More sharing options...
Chandler Posted June 20, 2013 Author Share Posted June 20, 2013 yep obd2 i hope so aswel mate Quote Link to comment Share on other sites More sharing options...
