Gilman Posted January 4, 2014 Share Posted January 4, 2014 Hey folksHas anyone fitted a tegiwa 3 point brace to their mb6? I am trying to fit one to my VTIS, the bolt holes line up ok but the base dosen't sit flat on top off the suspension tower. Was thinking to just fill the gap with washers but seems like a bit of a bodge. Any one elss noticed this with their's? Quote Link to comment Share on other sites More sharing options...
Krzys Posted January 4, 2014 Share Posted January 4, 2014 Noodels has one in his, might be worth sending him a PM or looking at his build thread? Quote Link to comment Share on other sites More sharing options...
noodels Posted January 4, 2014 Share Posted January 4, 2014 Noodels has one in his, might be worth sending him a PM or looking at his build thread?Did have just sold it to phil fitted alright on mine,<apart from when i fitted sk2 inlet> maybe 1 or 2 washers would be ok sure its not fitted wrong. Quote Link to comment Share on other sites More sharing options...
Krzys Posted January 4, 2014 Share Posted January 4, 2014 Did have just sold it to phil fitted alright on mine,<apart from when i fitted sk2 inlet> maybe 1 or 2 washers would be ok sure its not fitted wrong.I know you have, just figured being as you had fitted one you'd be able to shed some light Quote Link to comment Share on other sites More sharing options...
Gilman Posted January 4, 2014 Author Share Posted January 4, 2014 Did have just sold it to phil fitted alright on mine,<apart from when i fitted sk2 inlet> maybe 1 or 2 washers would be ok sure its not fitted wrong.Dont see how it could be fitted wrong, just undo the shock top bolts and slide the brace over and refit the bolts? or is there a better way of doing it?Does the sk2 inlet get in the way cos i was thinking of getting one of them aswell ? Quote Link to comment Share on other sites More sharing options...
philgor Posted January 4, 2014 Share Posted January 4, 2014 got it fitted to mine the other day, 2 issue's, n/s strut tower clearance v.tight with the a/c pipe's, and a 10mm gap between the 3rd mount and the bulkhead. the standard vti strut brace also fit's over the 3 pointer with no issue's either. and the difference is brilliant. Quote Link to comment Share on other sites More sharing options...
Gilman Posted January 4, 2014 Author Share Posted January 4, 2014 Yeah i have the same gap at the 3rd point against the bulkhead, gona use washers to fill the gap. A/C not a problem on mine as i ripped it all out.Good to hear the old brace still fits over, better give it a coat of paint Quote Link to comment Share on other sites More sharing options...
noodels Posted January 5, 2014 Share Posted January 5, 2014 quote:gap at the 3rd point against the bulkhead fitted nice to my bulkhead with no washers,may have just wound the bolts tight to get it all square.alsosk2 inlet get in the way,>>seemed to be a no no, but didnt try too hard tbh just needed to get rid of parts not being used atm. Quote Link to comment Share on other sites More sharing options...
noodels Posted January 5, 2014 Share Posted January 5, 2014 got it fitted to mine the other day, 2 issue's, n/s strut tower clearance v.tight with the a/c pipe's, and a 10mm gap between the 3rd mount and the bulkhead. the standard vti strut brace also fit's over the 3 pointer with no issue's either. and the difference is brilliant. glad you like and got home ok. Quote Link to comment Share on other sites More sharing options...
noodels Posted January 5, 2014 Share Posted January 5, 2014 LIKE this to raise to miss sk2 manifold , but with correct thread http://www.ebay.co.uk/itm/390064794392?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649 Quote Link to comment Share on other sites More sharing options...
