mb6 coil springs ?
mb6 1.8vti
i was told by my mechanic (who is a rover breakers yard) that the ones on my MB3 are the same as the rover ones and would fit the only thing i will say is check the weight difference between the rover they are for and your M as if there is a noticeable weight difference they may not sit right...
    i`ve notice the rover 45 have the same part no  for shoks. will they fit the coil springs too? anyone ........ . thanks
^^ This is right but as your profile says you have an MB6 I think you may have a problem with the spring rates due to the weight difference of the B18 and the (K series?).
Are you wanting standard springs or lowering ones?
