stevieob999 Posted February 19, 2010 Share Posted February 19, 2010 ok paint started bubbling of the drivers side arch. its not to bad but it irritates me alot. anyone fixed this before and if so what kinda money this gonna set me back? Link to comment Share on other sites More sharing options...
Dave Posted February 25, 2010 Share Posted February 25, 2010 depending how bad it is, if the blister is say 5p coin size, the damaged metal wll be around 10p coin sized. If you can get it grinded back and cleaned up, so that all the rusty metal is gone, you will be able to fill it and then repaint. The only problem with filler is shrinkage, and also the fact the rust usually finds its way back. New arches are available though, just the fitting that takes a bit of doing. Speak to Rich (civicturbo79) as his brother does bodywork and Rich knows a lot about it Link to comment Share on other sites More sharing options...
poundy81 Posted February 25, 2010 Share Posted February 25, 2010 Hi Dave,You say new arches are available. Is this for the MB6 and if so could you let me know who/where to get them please. I need both sides.Thanks Link to comment Share on other sites More sharing options...
Dave Posted February 25, 2010 Share Posted February 25, 2010 Hi mate, yeah you can get them. Order up a set for the rover 400, identical arches Try hadrians panels, or any good local motorfactors should be able to help out mate PS: Mind and fill in your profile mate in your user control panel Link to comment Share on other sites More sharing options...
-AL- Posted February 25, 2010 Share Posted February 25, 2010 Ian - Kent panels and paints should be able to help you out as They are also in Maidstone. Also know a bodyshop that wont rip you off over prices. Wich is in sheppy. Link to comment Share on other sites More sharing options...
civicturbo79 Posted February 25, 2010 Share Posted February 25, 2010 With rust you are always best to cut it out or it will be back in 6 months . for this sort of job though a bodyshop will want some good money as there is alot of work in cutting the archs off rewelding and filling and then you are into painting the 1/4's and blending the rear doors . i bet you would not see alot of change out of £1000 . Rich. Link to comment Share on other sites More sharing options...
