wantone Posted December 3, 2014 Share Posted December 3, 2014 So MC2/MB6 4x114 to EP3/DC5 5x114 hub swap, has anybody done this? Is it even doable? Been looking at getting some different wheels and the selection available for 5x114 is much larger than 4x114.... I have searched but come up with nothing Quote Link to comment Share on other sites More sharing options...
wantone Posted December 3, 2014 Author Share Posted December 3, 2014 Hmm, just found this c/o google http://technet.ff-squad.com/how-to/5lug.ef-da/ Quote Link to comment Share on other sites More sharing options...
Grant Posted December 3, 2014 Share Posted December 3, 2014 One has just popped up mate .. Check you "new content" Not sure if it was a ep or dc but 5stud nonetheless. Quote Link to comment Share on other sites More sharing options...
DeLaSoul Posted December 3, 2014 Share Posted December 3, 2014 I doubt you'd be able to fit DC5/EP3 hubs, especially at the rear as they are totally different setup - hence why you can't find anything. You can fit EK9/DC2 hubs all around which does convert you to 5x114.3 PCD and the larger wheel bearings at the front as I've done it to my MC2. I also switched drive shafts, but I believe you can just switch the outer ends and keep your original shaft. Rear fitting on mine 4 Quote Link to comment Share on other sites More sharing options...
Grant Posted December 3, 2014 Share Posted December 3, 2014 still need to come see this young man ! 1 Quote Link to comment Share on other sites More sharing options...
wantone Posted December 3, 2014 Author Share Posted December 3, 2014 I doubt you'd be able to fit DC5/EP3 hubs, especially at the rear as they are totally different setup - hence why you can't find anything. You can fit EK9/DC2 hubs all around which does convert you to 5x114.3 PCD and the larger wheel bearings at the front as I've done it to my MC2. I also switched drive shafts, but I believe you can just switch the outer ends and keep you original. Rear fitting on mine Nice! Thanks for the info Quote Link to comment Share on other sites More sharing options...
DeLaSoul Posted December 3, 2014 Share Posted December 3, 2014 still need to come see this young man !It's not going anywhere for a while! Only just started to test fit the new wheels over the big brakes and 225/45 tyres under the arches 1 Quote Link to comment Share on other sites More sharing options...
DeLaSoul Posted December 3, 2014 Share Posted December 3, 2014 Nice! Thanks for the infoNo problem Quote Link to comment Share on other sites More sharing options...
wantone Posted December 3, 2014 Author Share Posted December 3, 2014 They look similar to the hi-spec callipers i've just got my hands on! Dont suppose you know what size offset the brackets are? Not sure which ones i need - http://www.hispecmotorsport.co.uk/UniBrkB42.html Quote Link to comment Share on other sites More sharing options...
DeLaSoul Posted December 3, 2014 Share Posted December 3, 2014 They look similar to the hi-spec callipers i've just got my hands on! Dont suppose you know what size offset the brackets are? Not sure which ones i need - http://www.hispecmotorsport.co.uk/UniBrkB42.htmlNo but I can measure them later tonight. I bought the setup to match the DC2 hub, found some old photos while it was fitting it all together, excuse the mess s Quote Link to comment Share on other sites More sharing options...
