jalesi2001 Posted June 3, 2009 Share Posted June 3, 2009 Nice one Moe!! I have seen the third one before, but the one I saw was a bit dodgy looking, knowing my luck i would drop a collet or the valve through into the cylinder!!!! i still have my old kit for doing them on the CVH Ford engines.......!!!Slosei, if you are gonna attempt it without taking the head off, make sure the piston is at TDC on the cylinder you are doing!!! Or you may drop the valve into the cylinder, then its head off anyway!! Link to comment Share on other sites More sharing options...
Moe Posted June 3, 2009 Share Posted June 3, 2009 TBH its better to take the head off and do the job, then you can fit a spoon headgasket which will bump up the compression a bit Link to comment Share on other sites More sharing options...
slosei Posted June 3, 2009 Author Share Posted June 3, 2009 yup thems are the things i am after thanks Moesee if work can get them for me Link to comment Share on other sites More sharing options...
SteveMB6 Posted April 26, 2010 Share Posted April 26, 2010 Just to follow up on this and for info for anyone elseI have the same problem with burning oil - 10 litres in 5k miles to be exact lolParts ive ordered that will be fitted in 2 weeks time.Head Kit which includes head/rocker cover and manifold gaskets, valve stem oils seals(the culpret), and a variety of all other seals and small gaskets.Timing belt (may as well replace all belts this while the head is off)A/C beltPower steering beltAltenator beltOilOil filterParts came to £200 approxLooking forward to getting stuck in lol Link to comment Share on other sites More sharing options...
jonnyricer Posted April 27, 2010 Share Posted April 27, 2010 these genuine parts????if not what makehow much is a spoon hg?? Link to comment Share on other sites More sharing options...
SteveMB6 Posted April 28, 2010 Share Posted April 28, 2010 unfortunately not genuine honda parts, as i cant afford them, just from local motor factorsIve no idea how much a spoon hg would cost, probably a fortune lol Link to comment Share on other sites More sharing options...
civicturbo79 Posted April 28, 2010 Share Posted April 28, 2010 I would use all honda stuff mate as you do not want to be doing the job twice , Rich. Link to comment Share on other sites More sharing options...
jonnyricer Posted April 29, 2010 Share Posted April 29, 2010 i would use genuine parts for the hg(or spoon or similar)seals head bolts(can the bolts be re used???)but the rest iwould use good motor factors such as payen. Link to comment Share on other sites More sharing options...
civicturbo79 Posted April 30, 2010 Share Posted April 30, 2010 You can re-use them up to 3 times i think , but would you want tyo take the chance ,but for a set for a mb6 they are £97 Rich. Link to comment Share on other sites More sharing options...
supermike Posted April 30, 2010 Share Posted April 30, 2010 Just to follow up on this and for info for anyone elseI have the same problem with burning oil - 10 litres in 5k miles to be exact lolThats not a lot, i was burning 5 litres in one night, no problem! Now that was bad lol Link to comment Share on other sites More sharing options...
