digitalfaze Posted January 11, 2011 Share Posted January 11, 2011 P30 does fit, exactly the same connector as the p28 http://www.h-tune.co.uk/store/index.php ... tion_id=16 Link to comment Share on other sites More sharing options...
Gav_ek4 Posted January 12, 2011 Share Posted January 12, 2011 a p30 is obd1 so no good unless you get a conversion harness, also the popular thing to do with b series when it comes to mapping is to use a socketed p28. if you sell the p30 pm me. only reason why its popular is because its the most common obd1 ecu...p30 will chip fine unless its a small case (small square instead of large rectangular) jdm ecu ...these can still be chipped but are a lot harder to do and involve more mappingz due to needing the speed limiter removed and the knock sensor cuircuit disabled Why would you need a conversion harness to run a p28/p30 in a mb6 ...mb6 ecu is obd1 plugs with obd1 pinout running obd2 enginebay sensors My mb6 is running a jdm p72, Link to comment Share on other sites More sharing options...
johngreen537 Posted January 12, 2011 Share Posted January 12, 2011 P72 was used in Integra GSR / Non TR verison, more aggressive fuel maps, only needs a few pins soldering and plug mod to get it working on MB6 Link to comment Share on other sites More sharing options...
Gav_ek4 Posted January 12, 2011 Share Posted January 12, 2011 you dont need to solder any pins to run a p72...its plug and play ....plug mod is all thats needed...makes a huge difference though Link to comment Share on other sites More sharing options...
digitalfaze Posted January 12, 2011 Share Posted January 12, 2011 P30, P28 and P72 are all plug and play ecus, only plug mod required Link to comment Share on other sites More sharing options...
ra272 Posted January 13, 2011 Share Posted January 13, 2011 you dont need to solder any pins to run a p72...its plug and play ....plug mod is all thats needed...makes a huge difference thoughDon't you have a cell code ? the P72 has a knock sensor board, the B18c4 don't have a built in knock sensor. Link to comment Share on other sites More sharing options...
johngreen537 Posted January 14, 2011 Share Posted January 14, 2011 P72 you have to solder pins... Good how to here!http://cars.homenetcs.co.uk/honda-civic ... ns-ecu.htm Link to comment Share on other sites More sharing options...
Gav_ek4 Posted January 14, 2011 Share Posted January 14, 2011 i didnt have to???? Link to comment Share on other sites More sharing options...
KiNK43 Posted January 14, 2011 Share Posted January 14, 2011 You use stock p72 map? Or chip? Any good? Link to comment Share on other sites More sharing options...
digitalfaze Posted January 14, 2011 Share Posted January 14, 2011 think you would be better using a gsr map, unless you change the inlet manifold to a single stage Link to comment Share on other sites More sharing options...
