MA9 has code 48 after 225000 miles - O2 sensor?
15vtec-e
Hello - anything else to check for code 48 ? And can anyone recommend a good place to buy from?
First time the diagnostic light has come on. Engine still runs as normal once I reset (switch off and back on) the ignition and the engine light does not come back on. I think it must be temeperature related as I have a 5 wire sensor and when the engine has done a couple of miles it has enough ambient warmth to fool the sensor. Still sips petrol, so I'll keep it going for a bit longer if possible.
thanks
Hello Gel - thanks for the useful links. I've seen NGK 5 wire O2 sensors on the interweb - though costly. Just wanted to be sure the code 48 wasn't caused by another reason before buying.
Are you still running a 4 wire O2 sensor ? And what engine ? Mine is the cooking 15DZ3.
Pete
