ash d-series Posted May 20, 2010 Share Posted May 20, 2010 Its more likely to be valve stem seals than piston rings, if it was rings you would probably have trouble with starting due to loss of compression Link to comment Share on other sites More sharing options...
SteveMB6 Posted May 21, 2010 Share Posted May 21, 2010 Its more likely to be valve stem seals than piston rings, if it was rings you would probably have trouble with starting due to loss of compressionNo mate, it would start fine as its not that bad. I think that both should be replaced. Link to comment Share on other sites More sharing options...
digitalfaze Posted May 22, 2010 Author Share Posted May 22, 2010 Well the compression in each cylinder was 17 bar so the head is getting rebuilt with labour of £170, im supplying the parts so any advise on the parts i should be buying, everything uprated Considering cams while the head is off Link to comment Share on other sites More sharing options...
SteveMB6 Posted May 23, 2010 Share Posted May 23, 2010 thats a very good price for labour, the job will take about 8-10hrs Link to comment Share on other sites More sharing options...
digitalfaze Posted May 23, 2010 Author Share Posted May 23, 2010 Yeah he's a friend of a friend and use to work for AWD Motorsport.Im gonna be ordering some parts for it, you know if the following are worth forking out for:Spoon Valve Stem SealsSpoon HeadgasketAlso discovered i need new plugs:Denso IridiumSplitfireSpoon Link to comment Share on other sites More sharing options...
civicturbo79 Posted May 23, 2010 Share Posted May 23, 2010 I would use standard headgasket and valve stem seals, i do not think you well get anything out of the extra cost . As for the plugs i would go for Denso IridiumRich. Link to comment Share on other sites More sharing options...
digitalfaze Posted May 23, 2010 Author Share Posted May 23, 2010 Ok denso it is,the head gasket says it raises compression, i plan on doin more mods to the car in future so would it not be better to put the better spoon parts in while i can Link to comment Share on other sites More sharing options...
civicturbo79 Posted May 23, 2010 Share Posted May 23, 2010 I ran 379 bhp 26psi of boost all on a standard honda headgasket and it never let go , so im sure you will not blow it with n/a mods . Rich. Link to comment Share on other sites More sharing options...
SteveMB6 Posted May 24, 2010 Share Posted May 24, 2010 imo some aftermarket parts are a waste of money, unless you have very big plans Link to comment Share on other sites More sharing options...
digitalfaze Posted May 24, 2010 Author Share Posted May 24, 2010 I want to get this car to 200+bhp but really want to have some decent power in the low revs, i think they are crap up to 4500rpm, but dont know which way to do it, i am thinking throttle body and inlet manifold , exhaust first off, then cams, springs, retainers, cam gears, a good map then hopefully i will be looking to put some pistons in to get it all running sweet.Would love to turbo it in the future too . But the things i have in my basket just nowHonda Head GasketDenso plugsMagnecor Ignition leadsValve stem seals (not sure on honda or spoon?)Timing belt, will i need a tensioner bearing?Professional Products Throttle Body unsure of the size but here is the link: http://www.funkypower.co.uk/catalogue.p ... oduct=4312Then the next buy will be a Skunk2 inlet manifoldWhat do you think? Link to comment Share on other sites More sharing options...
