digitalfaze Posted May 5, 2010 Share Posted May 5, 2010 My mb6 started blowing blue smoke in vtec which i was told was pistonrings, the garages i called refuse to the car on to do the repair and recommended getting a new engine.So i need an engine for my mb6 which currently has a teg dc2 bottom end. can i get advise on what i would need to do and buy to fit a teg engine in the car? (ecu?, gearbox?, clutch?)Also any upgrades that should be done while im there, i want to replace the clutch but dont know if i need to buy a teg cluch or a mb6 clutch etc etc.I just want to know what i need to buy so i can purchase any needed parts and give it all to a garage to fit at once, with no real problems.Thanks in advance Link to comment Share on other sites More sharing options...
civicturbo79 Posted May 6, 2010 Share Posted May 6, 2010 You will need £2000 plus just for the teg engine with low mileage , just rebuild the one you have loads easier than fitting a teg lump ans cheaper , you will need new pistons anyway so just get high comp stuff with a b16 or a b18 teg head and you will have the same as a teg engine anyway (almost). Then get a mapable ecu and get it mapped . job done . Rich. Link to comment Share on other sites More sharing options...
digitalfaze Posted May 9, 2010 Author Share Posted May 9, 2010 I cant really have any downtime on my car as its my daily comuting car, i also have no idea who would take on the rebuild, i did get offered a teg engine for 600 fitted but was unsure as there was no ecu, box or inlet manifold.how long will a car last with knackered piston rings Link to comment Share on other sites More sharing options...
digitalfaze Posted May 9, 2010 Author Share Posted May 9, 2010 ok i understand now, When purchasing pistons what should i be looking for, i see funkypower do spoon pistons for b16 engine, would these fit to my teg bottom end (if i was to get b16 head).will there be more advantages to getting a b16 head on the teg bottom end? faster??? Link to comment Share on other sites More sharing options...
SteveMB6 Posted May 10, 2010 Share Posted May 10, 2010 it might not be your rings, get a compression test done, if its holding good compression it will just be your valve stem oil seal on the head, which can be done in a day....a long day lol Link to comment Share on other sites More sharing options...
digitalfaze Posted May 10, 2010 Author Share Posted May 10, 2010 To be honest the garage never even said if they done a compression test on the car although all signs show piston rings,I quite like the idea of buying a new head, pistons and ecu. But need some advise on the parts i need (im not very knowledgeable when it comes to cars)If a b16 head makes it go faster im all for that, i will buy the spoon pistons and get a recommended mapable ecuCheers guys ur help is much appreciated Link to comment Share on other sites More sharing options...
civicturbo79 Posted May 10, 2010 Share Posted May 10, 2010 If you want pistons and rods , bearings and so on for a bottom end build you are best to get all the parts you need from the states they are loads cheaper and you can get all the parts in one go , you can fit a b16 head it would help with the single stage vtec like a teg but you will have wiring problems , but if you use a b18 head with a single stage manifold you will get the same effect , just get some nice cams and you b18 c4 head will almost be as good as a teg head anyway . Rich. Link to comment Share on other sites More sharing options...
digitalfaze Posted May 10, 2010 Author Share Posted May 10, 2010 Cheers rich,If i use my b18c head will i not have to get it honed and buy bigger pistons anyway? i take it not just as simple as buying pistons and rods, prob loads of other things i need to think about? i shall have a look to see if i can find a b18c head somewhere then think about the other parts i may need.do you know a rough price i will be looking to pay for a garage to rebuild the bottom end? im hoping a budget of £1000 give or take a couple of hundred would cover getting it back to a1 condition engine wise? Link to comment Share on other sites More sharing options...
civicturbo79 Posted May 11, 2010 Share Posted May 11, 2010 you would have to remove the engine and strip it down , get the block check and measured you would have to go at least 0.5 over size on the pistons and have the block bored out by 0,5 mm as well . so they are a perfect match , the same with the crank you will have to have that check and measured just in case but they are usually ok , but if its not again mechine 0.25mm off min and get over size bearings to match , The key to a good build is get everything checked . As for your £1000 budget , i think you will be hard pushed as the parts to build the bottom end with all the mechine work will be close to that ,if not over , i will need more like a £2000 budget . Pistons are around £350 rods are around £250 bearings big end and mains £150 head set £220cambelt £55 oil pump stage 1 £110 rebore £50 head skimmed £25 crank if it need mechining £30 Labour 20 hours at £60 an hour £1200 Rich. Link to comment Share on other sites More sharing options...
jalesi2001 Posted May 11, 2010 Share Posted May 11, 2010 £60 p/h labour? Thats cheap mate, your worth more than that!! Link to comment Share on other sites More sharing options...
