craigb Posted June 28, 2009 Share Posted June 28, 2009 hi all i have a 99 vti mb6 and ive got a problem where when the car is warmed up it tries to cut out at junctions with the revs bouncing from 1500 down to 200, it also happens if im stationary and just blip the throttle but again only when warmed upplease can anyone help Link to comment Share on other sites More sharing options...
Dave Posted June 28, 2009 Share Posted June 28, 2009 sounds like idle control valve, or a leak at the inlet manifold? hard to say, maybe someone else can say for sure. Link to comment Share on other sites More sharing options...
jalesi2001 Posted June 28, 2009 Share Posted June 28, 2009 Yeah, does sound like a sticky/ partly siezed idle control valve. Try removing it and cleaning it with brake cleaner or carb cleaner, if it dont work you may need a new one im afraid. Is the engine management light on? Link to comment Share on other sites More sharing options...
craigb Posted June 29, 2009 Author Share Posted June 29, 2009 thanks for your fast replies. no the engine management lights not on and ive cleaned out the iacv. when i had it out i put power to the terminals and it moved up and down. has anyone had this before thanks again in advance craigb Link to comment Share on other sites More sharing options...
Moe Posted June 29, 2009 Share Posted June 29, 2009 a leak somewhere around the inlet, maybe a vac pipe? oxygen sensor on its way out? Link to comment Share on other sites More sharing options...
