  • 0
D15Z8 timingbelt
quinnamb3
currently im working on my civic MB3 with D15Z8 vtec E,
is there any way possible to block the crankshaft from turning??
thanks in advance.
Kind regards,
Quincy Habing
1 answer to this question
  • 0
If you want to prevent the crank from turning, for example to undo the crank bolt, then you can either get a special tool (see picture), or undo the dust protection plate for the clutch and either jam a sturdy screwdriver or something else against the teeth on the flywheel to keep it in place.
httpswww.all4honda.comimagesstoriesvirtuemartproductoem-honda-krukas-poelie-blokkeer-gereedschap-50mm-universeel--oem-csbt--all4honda.jpg.f903dc5193318910329372b11b555bef.jpg
But that bolt is often super tight (>200NM torque), so beware when you go for the flywheel route!
Answer this question...
