whats wrong
lacos
had comp test done and there is no abnormal difference between the four cylinders they were all 165 now i am not sure if that is in psi or bar what should they be . how much would it cost for a rebuild nothing fancy just slight over bore and new bearings and pistons , i am sure some thing is not right it just sounds strained and slow to rev up
  • 3 weeks later...
  • Replies 24
x23! Spark plug seals in the rocker cover!
If it were internal stem seals or oil seals, you be checuking oil into the combustion chamber and blowing it out of the exhaust on VTEC!
Also, if oil O ring seals were gone, you'd notice wafts of blue smoke on throttle lift off. Get someone to look at the exhaust while you blip the throttle!
