King Posted September 17, 2010 Share Posted September 17, 2010 Just got a fog light problem I hope you guys can help me out with, my drivers side fog light doesn't work, I've changed the bulb and checked the connections but no luck. where could I find the fuse? But i thought if the fuse is blown then they both wouldn't work? Thanks Link to comment Share on other sites More sharing options...
King Posted September 17, 2010 Author Share Posted September 17, 2010 Just got a fog light problem I hope you guys can help me out with, my drivers side fog light doesn't work, I've changed the bulb and checked the connections but no luck. where could I find the fuse? But i thought if the fuse is blown then they both wouldn't work? Thanks Link to comment Share on other sites More sharing options...
james Posted September 18, 2010 Share Posted September 18, 2010 i do not realy know matethe fuses are in side the car the little pocket above your legs under the steering wheel that comes out pull it out the pull it up pop the bottom out and voulamight wana check the fuses in the engine bay 2i know you checked the cenections but thats what it sounds likesome body here will surely know anyway Link to comment Share on other sites More sharing options...
nova2fit4u Posted September 18, 2010 Share Posted September 18, 2010 I got the same problem how do i change the bulb inside the fog lights Link to comment Share on other sites More sharing options...
simpo Posted September 19, 2010 Share Posted September 19, 2010 why dont you take the one that works and plug it in the one that doesent. if it works then you know its the unit and you will need a new fog light Link to comment Share on other sites More sharing options...
james Posted September 19, 2010 Share Posted September 19, 2010 ah so simple but so effective Link to comment Share on other sites More sharing options...
