E=MC2 Posted December 17, 2010 Share Posted December 17, 2010 guys, i have problem with b18c4 and it is worse day after dayin advance sorry for bad englishthis is my problemshortly after i bought my car i've noticed that when it reach working temp. and drive for a while, start to have problem with low rpm's (till 2500rpm)on every hard press on gass pedal, motor sound like it lose spark, or swallow to many air, or lose fuel... and start to decrease rpm's and go to complete shut down if you do not release gas.If i reduce press on accelerator, car restore idle.if i slowly cross this area, engine very healthy work all the way until the rpm limiteri bought new spark plugs (ngk bkr7ne-11), and few days ago replace ignition cap with new one, and nothing, maybe even worsenow car ignite very hard, and when reach normal temp, start to do same thing, but now till 4000rpm and on half semi strong pedal press.does anyone know what might be a problemb.t.w. i dont have check engine lighthelp please, thanks Link to comment Share on other sites More sharing options...
johngreen537 Posted December 17, 2010 Share Posted December 17, 2010 I had the same problem on an EK mate. Turned out to be a misfire caused by a dodgey HT / ignition lead.I'd start by changing the ignition leads, then may be worth looking at the distributer rotor arm. Link to comment Share on other sites More sharing options...
E=MC2 Posted December 17, 2010 Author Share Posted December 17, 2010 guys from car service told me that it might be a crank position sensor Link to comment Share on other sites More sharing options...
johngreen537 Posted December 17, 2010 Share Posted December 17, 2010 It's posible mate, but i'd have thought an ECL would appear for a CPS issue...I'd start with the simple stuff, like HT leads. Even if it's not the cause of the issue, it's a cheap part to replace! Link to comment Share on other sites More sharing options...
E=MC2 Posted December 17, 2010 Author Share Posted December 17, 2010 sry, what is ECLleads i will probably replace, bu not sooner than next week, and i want now what is wrong with engine. Link to comment Share on other sites More sharing options...
johngreen537 Posted December 17, 2010 Share Posted December 17, 2010 Engine Check Light... Link to comment Share on other sites More sharing options...
bepilot Posted December 17, 2010 Share Posted December 17, 2010 same problem I had, but I changed the whole distributor, an ebay one 110eu delivred. My civic is a daily driver and I didn't want to hassle to change this, then this and finally still have the problemnormally you should also change rotor if you did the cap at the same time... so maybe try at least the rotor if you don't want to buy a full distributor... Link to comment Share on other sites More sharing options...
E=MC2 Posted December 17, 2010 Author Share Posted December 17, 2010 some guy on other forum told me that the old enigne belt can make bat reading on CPS, because of little streched belt sensor read bad data2 bepilot - i bought rotor allso with cap, but they delivered me bad type, so i have to replace it with appropriate one Link to comment Share on other sites More sharing options...
johngreen537 Posted December 17, 2010 Share Posted December 17, 2010 some guy on other forum told me that the old enigne belt can make bat reading on CPS, because of little streched belt sensor read bad dataI don't beleive that mate. I could be wrong, but it sounds really unlikely :S Link to comment Share on other sites More sharing options...
civicturbo79 Posted December 17, 2010 Share Posted December 17, 2010 Mt brother car has the same problem and i have changed everything including the coil in the distributer and it still has the problem , the distributers and a commen problem i would say you will need a new one as my brother does for his , Rich. Link to comment Share on other sites More sharing options...
