E=MC2 Posted December 17, 2010 Author Share Posted December 17, 2010 heh, thats last thing i wanted to hear ok, i shall probably tommorow investigate what can be cause of this problemif anyone has contact with this mailfunction, feel free to write, i would be gratefull Link to comment Share on other sites More sharing options...
Gav_ek4 Posted December 18, 2010 Share Posted December 18, 2010 before buying a distributer, unplug the lambda/o2 sensor from the exhaust(plug is at back of engine above the cat ) take the car a run and see if the problem goes away ...my vti-s had this exact problem and it turned out to mbe a faulty o2 sensor(runs fine with it unplugged) but the management light will come on after a mile or so but it will go back out when you plug a new one in Link to comment Share on other sites More sharing options...
civicturbo79 Posted December 18, 2010 Share Posted December 18, 2010 before buying a distributer, unplug the lambda/o2 sensor from the exhaust(plug is at back of engine above the cat ) take the car a run and see if the problem goes away ...my vti-s had this exact problem and it turned out to mbe a faulty o2 sensor(runs fine with it unplugged) but the management light will come on after a mile or so but it will go back out when you plug a new one indid your engine managment light not come on then due to the faulty o2 sensor ? But only once you unpluged it . At the point of the o2 sensor being unpluged did the fault stop ? But the engine managment light was on . Rich. Link to comment Share on other sites More sharing options...
E=MC2 Posted December 18, 2010 Author Share Posted December 18, 2010 i've started car today normaly, drive it few km's, and problem arived againfor first started to lose gas, and then shut down completelytried to start a car, lost battery, tow car to friends garage, unplugged o2 sensor, bypassed battery from brothers car, and tried to start the engine. but the engine couldnt startspark plugs give fine spark, so i think that the coil is not the problemso, to summarize.cold engine work normaly, and when it reach working temp. start to have problemsfriend mechanic think that the probolem is ecu or cpsno map, no tps, no mechanical problem, just electricalhelp, i am very confused Link to comment Share on other sites More sharing options...
bepilot Posted December 19, 2010 Share Posted December 19, 2010 I continue to hammer for the distributor mate - exactly same symptoms as mine!bought mine here, I give you the link this time - no problems anymore (it took 1,5 weeks to arrive but it's the cheapest shipping on ebay)http://cgi.ebay.com/ebaymotors/HONDA-ACURA-IGNITION-DISTRIBUTOR-96-01-B16-DOHC-VTEC-_W0QQcmdZViewItemQQfitsZSubmodelQ3aGSQ2dRQQhashZitem53e5477d6dQQitemZ360328953197QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessoriesIf you want to buy elsewhere, make sure its an OBD2 one for VTEC engine, original ref is TD-86U Link to comment Share on other sites More sharing options...
E=MC2 Posted December 19, 2010 Author Share Posted December 19, 2010 few people told me that the coil is problemit is not expencive to replace it90 euros is original coil in honda storejust to check is it coil and to replace it Link to comment Share on other sites More sharing options...
E=MC2 Posted December 20, 2010 Author Share Posted December 20, 2010 hey, bepilot, distributor on the link is "HONDA ACURA IGNITION DISTRIBUTOR 96-01 B16 DOHC VTEC" how can it fit on b18? Link to comment Share on other sites More sharing options...
johngreen537 Posted December 20, 2010 Share Posted December 20, 2010 They are fundamentally the same engines mate... B16 / B18As long as it's a ODB2, you'll be fine Link to comment Share on other sites More sharing options...
E=MC2 Posted December 20, 2010 Author Share Posted December 20, 2010 I'm just asking because I heard somewhere that the distributors are not the same Link to comment Share on other sites More sharing options...
johngreen537 Posted December 20, 2010 Share Posted December 20, 2010 For peace of mind mate, check your part number matches Link to comment Share on other sites More sharing options...
