engine very unstable below 3000 rpm
E=MC2
as it says... that's why I gave you a picture of the original reference of my old distributor, TD86U
Brand New Acura & Honda Ignition Distributor
Honda/Acura OEM Ref. # TD81U & TD84U & TD86U & TD87U
DOHC VTEC ONLY
Complete with Distributor, Cap, Coil and Rotor
In the ebay comment box during my purchase, I re-insisted for having the right equivalent.
On the package I received from them it was noted TD81U, but the distributor worked OK, I just changed the wire attachment point, but that's a minor detail honestly.
Honda is quite known for having multiple references for one similar piece, so don't worry about that.
  • Replies 28
nothing :(
new coil, new ignition module and not even close to igniting
main relay do usual click, sparks give strong spark, coil, modul and sparks wires are wired by the book, injectors recieve electrical signal during engine starting, they are spraying fuel in the combustion chamber.... bot not even cough from the engine
can be engine timing, ecu (which one was serviced once because of bad idle), some sensor (theres no ECL on dash)...?
  • 4 weeks later...
problem solved
bad fuel pressure was cause of everything
mechanic replaced fuel pump, fuel filter, fpr, spark plugs, and made full injector service
  • 2 months later...
