how do i reset ecu, done search already
vtivtec170
  • Replies 52
  belfastlad123 said:
im confused lol what do i do .will it make any diifference ??
It did with my mb6 (the guild i used was for the mb6)! but you have got a mb3 (which i didn't spot) sorry :oops: . So i'm not sure mate! :(
Im going to give this a go, but the problem im having is that the backup fuse is not present in my mb6, so the slot is empty. Do i need to have this fuse inorder to complete the reset or shall i just performthe reset with just the ecu fuse???
  belfastlad123 said:
fs lads i want to do mine(mb3) lol how can i reset the fuel settings.think i have a flat spot from i got my new exhaust on
Logically speaking if one method cant be done(no fuse option) the do the other method (negative lead off). I recomend before bed time just take the neg lead off and put it back on in the morning...
no back up fuse means no memmory ?
so you must have one or it mite have been chainged to a 10 amp .
if you cant find it you can try turning your ignition on and off 21 times this also resets the ecu .
then after the last time start it up and allow to idle till fan cuts in the turn it off .
its as easy as that mate :)
