s11aba Posted May 30, 2011 Author Share Posted May 30, 2011 Yeh the fluid is there. I was driving stopd at traffic light tried to put it in first and it didnt go in so switched the car off and then it went in fine. So when the car is started that when it does not go in gears. Link to comment Share on other sites More sharing options...
SteveMB6 Posted May 31, 2011 Share Posted May 31, 2011 is the system bleed properly?it probably is the release bearing. But i would replace the whole clutch while the gearbox is off Link to comment Share on other sites More sharing options...
s11aba Posted May 31, 2011 Author Share Posted May 31, 2011 had new clutch fitted bout year and half ago aint driven the car much aswel. Link to comment Share on other sites More sharing options...
SteveMB6 Posted June 1, 2011 Share Posted June 1, 2011 where is the noise coming from?get a mate to take off very slowly with the bonnet up and listen in from the outside. Link to comment Share on other sites More sharing options...
s11aba Posted June 1, 2011 Author Share Posted June 1, 2011 know there is no noise at all when the car is started it will not go in gears at all when you turned the car off that when it will go in gears Link to comment Share on other sites More sharing options...
bs_vti-s Posted June 1, 2011 Share Posted June 1, 2011 is it not more likely that its the gearbox rather than the clutch Link to comment Share on other sites More sharing options...
s11aba Posted June 1, 2011 Author Share Posted June 1, 2011 but then i wouldnt go in gears at all even when the car is turned off Link to comment Share on other sites More sharing options...
beastgtir Posted June 1, 2011 Share Posted June 1, 2011 my mate had the same problem, clutch melted onto flywheel..it could have been a fake exedy clutch buddy.. Link to comment Share on other sites More sharing options...
s11aba Posted June 1, 2011 Author Share Posted June 1, 2011 not sure if it was fake or geniune..... Link to comment Share on other sites More sharing options...
beastgtir Posted June 1, 2011 Share Posted June 1, 2011 would be the only explanation, exedy clutches are usually very good and to be honest they last a fair bit, also i havent seen you out n about in ages so imagine you haven't done very much miles on it!could be a broken spring in the clutch also, i'd be contacting the place where you got it from, or it could have been badly fitted? Link to comment Share on other sites More sharing options...
