mc2 with full vtis kit mmm (new pics) red wrinkle/poly bush
shebabby
Your doing a cracking job mate very impressed i like the full rad aswell how much was that?
thanks lads :D
it has been cold but worth every minute :lol:
as for the scooby rad i did order one for the civic from ebay but they sent me this one !
at first i spat the dummy out :( but then thought f#ck it .the rad i orderd was £89 and the scooby rad was £169 so that was goodenough
for me. also they come with low power slimline fans civic rad (one) fan/ scooby rad (two) fans 8-)
plus will make the engine run cooler with all the paint on it :lol:
If you read the posts he tells you! :roll:
thanks mate :D
the rad i orderd was £89 but they sent me this one which should have been £169 8-) so it was a real bargain at £89 :D
thanks lads :D
:lol: thanks paul
Also that poly bush kit for the linkage where from and how much i need to install that on mine before i put my short shifter on, really does look like a nice breath of fresh air to your motor well done cant wait to see it done.
i did read but aint feeling too well so skipped a little :oops:
the linkage bushes was also off ebay they were £19.80 + 3.75 p+p from racing xs but iv just seen that tegiwa online are doing similar ones
for £15 + 3.50 p+p
i will tell you that we fitted the same ones but in black to my mates deck and now there is quite a bad vibration through the gear stick
at around 7000 rpm ?
i suppose thats coz the softer they are they will absorb the vibration like shock absorbers on tennis rackets but if they hard stiff rubber then i suppose they wont asorb as much and just amplify the vibrations.
does it make a big difference to the feel of the gear change people rave about the poly bush kits but im yet to be won over standard bushes replaced on time seem as good unless your track daying the car then i can see why.
think youve hit it on the head there mate with the bushs :idea:
as for the difference they have made the gear change more like slotting gears together with a stick :lol:
and so far he hasnt missed a gear :P
the gears ar so much easyer to select now :)
Ok and the fact they will last ten times longer with them being hardened so i think i might go for them you know.
Thanks keep up the good work and next time i will read in a bit more detail as to not upset pauls keen eye! :ugeek:
1"£££$££"
