zKapa Posted September 7, 2011 Share Posted September 7, 2011 Hi everyone.Here is my MB1 i bought May 29th, 2010 I already posted in the "New Member" section, but i'll continue the progress here Original Engine:D16Y2 V-TEC 126hpHere it goes:When i bought it:After a full wash:New Stereo and Speakers!Speaker install with home-made spacer-adapterRemoving the ressonator Ressonator is OUT!!So far, it was August 2010, everything was fine, but the engine was "drinking" (a term used in Portugal) too much oil. When i rev'd, a lot of white smoke so, there was a problem to take care of......But not in time =(25th Semptember 2010... On a trip from my home city (Viseu) to Algarve (almost 400 miles) this happend:Only 40miles to arrive, I stop'd to put more gas ang go.I rev'd a quite after leaving the ServiceArea... was @ 208kmh/130mph, for about 3 minutes... all of a sudden the engine started to make some weird noises... i slowed down right away, but the noises were getting worse... =(Enginel Light? Off Oil Light? Off Stop'd at the next ServiceArea... didn't know what to do, or what the problem was. No lights on the dash so i was confused... =/15min later, started the engine again... noises were worse... went off anyway... I just wanted to arrive asap... but slowly...3~4 miles after, the engine started to brake itself... clutch down, engine stops immediately... pull'd over...Called the trailer (i think its how its called).The guy come's out of the trailer and simply asks about the Oil! and i'm like "how could i forget that? but wait, the oil light was off" Well... the problem was that in those 3 minutes i rev'd/@130mph, all the oil went out...Could only be solved with new engine...Old/original one (some parts were removed already for swap):New Engine:D16A9 Non-VTEC 130hp(known for CRX/Concerto 16i16)Cam position Sensor... i had to do that... Distributor was DoHC and the cable adapter was SoHCWhile the engine was being swap'd, i bought some gifts:Tenzo-R Short Shift + Seatbelt Honda PadsFinally, here is the video of the engine working some minutes after 1st start 0O20NL4fboo Safe Mode on (3500rpm cut) due to original ECU not compatible with D16A9 engine.I have more pictures to post, i'll update as soon as possible.Thanks guys Link to comment Share on other sites More sharing options...
WilkesyMB6 Posted September 7, 2011 Share Posted September 7, 2011 Looks good mate, my dad had a concerto with that engine and never had a thing go wrong with it. Link to comment Share on other sites More sharing options...
DAVEMB2 Posted September 7, 2011 Share Posted September 7, 2011 nice one some good work done whats next for her 1"£££$££"!! 1"£££$££"!! Link to comment Share on other sites More sharing options...
SteveMB6 Posted September 8, 2011 Share Posted September 8, 2011 Nice one mate, and a much better engine in it now. Probably a good bit quicker too. Those engines also came in the old rover 216 gti. Link to comment Share on other sites More sharing options...
zKapa Posted September 8, 2011 Author Share Posted September 8, 2011 Yes, it alsco came in the Rover 216 GTi. Actually this engine got a little more low/mid-range Torque than the last one.I love that low-rpm pull btw, the ECU is remapped after 3500rpm. You feel a little "bump" @ 3500rpm, and till redline (remapped to 8k rpm)... it's like a beast!! lolI'll post more pictures of some mods & repairs. Link to comment Share on other sites More sharing options...
Guest Posted September 8, 2011 Share Posted September 8, 2011 Hi mate, how hard was the swap. I was looking in to doin the same with my mb2 as I found a full engine for 60 notes. I asked around on loads or forums but nobody replyed to me. Prob because its not been done brfore. Link to comment Share on other sites More sharing options...
zKapa Posted September 8, 2011 Author Share Posted September 8, 2011 Hi mate, how hard was the swap. I was looking in to doin the same with my mb2 as I found a full engine for 60 notes. I asked around on loads or forums but nobody replyed to me. Prob because its not been done brfore.Well, you have a D14A7 90hp, i think.If you got an S20 or S40 gearbox, its plug and play. So, no problem with that.Check that first What you will need :-ECU from CRX/Concerto 16i16 (The CRX ECU is more "aggressive")-ECU cable harness for the engine,-Engine mount (the one near the camshaft) and i'll show you a picture why you need it.Be carefull, if the "new" engine does not have a Distributor, u have to buy one.SoHC distributors dont fit on DoHC engines.If it doesn't have a Distributor, it also means u need spark plug cables... and again, SoHC fit but they are too long and dont cover the spark plug holes.If u need any more info about the swap, let me know and i'll try to help you the best I can Cheers Link to comment Share on other sites More sharing options...
pj46 Posted September 8, 2011 Share Posted September 8, 2011 Loooking good mate, sweet looking car with loads of potential!! Link to comment Share on other sites More sharing options...
Guest Posted September 10, 2011 Share Posted September 10, 2011 Thanks dude, my mate has the same in his rex and he was saying that the only box that fits was a l3 but I aint heard of that one before. Link to comment Share on other sites More sharing options...
zKapa Posted September 14, 2011 Author Share Posted September 14, 2011 Latest video.tSEUF6F7f1k ECU remapped.Redline @ 8000rpmEngine is full stock.Pull done in 2nd gear. Reached 150kmh / 95mph Link to comment Share on other sites More sharing options...
