james Posted September 12, 2011 Share Posted September 12, 2011 By the way I had a look at your build up james, really nice car. thanks dude check this out for all you want to know viewtopic.php?f=86&t=3895&p=45692&hilit=mongoose+exhaust#p45692ill pm you the link now for the manifold Link to comment Share on other sites More sharing options...
shamz Posted September 13, 2011 Author Share Posted September 13, 2011 Thanx for the pm dude. Yep I stumbled across the link above on my initial research. I emailed ricerocket asking them about gaskets, he replied back saying mongoose systems use high temp silicone sealer when fitting exhausts. Link to comment Share on other sites More sharing options...
james Posted September 13, 2011 Share Posted September 13, 2011 na for get that shizz get your self this: www.ebay.co.ukcombine both paste and gasket together and you have a life time seal Link to comment Share on other sites More sharing options...
shamz Posted September 13, 2011 Author Share Posted September 13, 2011 Yep I read about the triangle gasket on your thread. How about the gasket in between the manifold and cat, gasket for mid to the back box? Will eurocarparts stock them? Link to comment Share on other sites More sharing options...
james Posted September 13, 2011 Share Posted September 13, 2011 you need two gaskets the triangle one and a o ring one here: www.ebay.co.ukthe rear section bend is a clamp job do gasket needed it just slides togther so use some paste there Link to comment Share on other sites More sharing options...
james Posted September 13, 2011 Share Posted September 13, 2011 i will delete the links when you have read this shamz due to admins not allowing them being posted so take note Link to comment Share on other sites More sharing options...
shamz Posted September 13, 2011 Author Share Posted September 13, 2011 Thanx james your a top bloke. I've copied all the links over lol. I'll give you a shout if you don't mint if I stumble across anything. I contacted tegiwa regarding the adjustable cat, apparently I need a 2" bore cat in order to fit it on my oem manifold Link to comment Share on other sites More sharing options...
james Posted September 13, 2011 Share Posted September 13, 2011 yep 2" is the one Link to comment Share on other sites More sharing options...
shamz Posted November 22, 2011 Author Share Posted November 22, 2011 Right so I decided for the time being I'm going to leave the oem cat and manifold. I put the mongoose exhaust on and the rear part of the mid and the pipe going from the mid to the backbox is hanging just like the oem one was. Problem is I'm scraping my brand new exhaust . Any ideas of how I can make it sit higher. Was thinking maybe shorter exhaust mounts?? If so which one? Thanx. Link to comment Share on other sites More sharing options...
james Posted November 22, 2011 Share Posted November 22, 2011 no its a fixed pipe Link to comment Share on other sites More sharing options...
