Stu_civicsport Posted September 30, 2011 Share Posted September 30, 2011 Dont no how to fix this played around with the connects on the speakers and it comes on but the cutes off again what should i do ? Link to comment Share on other sites More sharing options...
ryan.. Posted September 30, 2011 Share Posted September 30, 2011 are the connections good where the wire connects to the connectors?also could be a break in the wire someware?I guess this is oem wiring run off the headunit and oem speakers? Link to comment Share on other sites More sharing options...
simpo Posted October 1, 2011 Share Posted October 1, 2011 i would take the speaker out of the other side and see wat happens. if the speakers is the same cuts in and out then its your wiring but if it works fine then is your speaker. both pretty easy to fix if its the speaker then replace lol if wiring then run new wiring from head unit with new connections Link to comment Share on other sites More sharing options...
King Posted October 1, 2011 Share Posted October 1, 2011 Check to see if you have any exposed wires and if so get some insulation tape on them as they may be shorting out. Link to comment Share on other sites More sharing options...
