Cynabal Posted January 13, 2012 Share Posted January 13, 2012 Ok i removed my washer jets and fitted jazz mist ones, its much better but would still like more pressure, any way to get more pressure in the system? Quote Link to comment Share on other sites More sharing options...
beastgtir Posted January 13, 2012 Share Posted January 13, 2012 the blowing an airline thru the pipework to clear out the gunk in them. Quote Link to comment Share on other sites More sharing options...
Didjeridave Posted January 13, 2012 Share Posted January 13, 2012 wider piping will help too. You'll likely have quite a unique mod then...! Quote Link to comment Share on other sites More sharing options...
civicturbo79 Posted January 14, 2012 Share Posted January 14, 2012 i would go for a new pump , you would need smaller pipe to increase the pressure . Rich. Quote Link to comment Share on other sites More sharing options...
Didjeridave Posted January 14, 2012 Share Posted January 14, 2012 Surely with the same pump smaller piping will give higher particle velocity, but more pressure loss per unit length? The same pump would produce a higher pressure at the nozzle with wider piping, the nozzle jet size will then determine the particle velocity of fluid exiting the nozzle. Quote Link to comment Share on other sites More sharing options...
Cynabal Posted January 14, 2012 Author Share Posted January 14, 2012 I was looking at new pump but thought I'd try other avenues first, ill try just cleaning everything. Quote Link to comment Share on other sites More sharing options...
hickster Posted January 14, 2012 Share Posted January 14, 2012 Portable 12v jetwash wired in to the system Quote Link to comment Share on other sites More sharing options...
Didjeridave Posted January 14, 2012 Share Posted January 14, 2012 A bigger pump will certainly give higher volume velocity (i.e. flow/lph) & thus increase pressure at the end of the pipe/nozzle input, but it may well be cheaper to widen the piping & you may see satisfactory improvement without having to engineer in a different pump. For a spray system like this, you ideally don't want any restriction until the nozzle, so piping needs to be as wide and as short as possible to reduce pressure losses - 6mm OD piping is pretty restrictive; try blowing down a length of a few meters & you may appreciate this! Quote Link to comment Share on other sites More sharing options...
mark.b Posted January 19, 2012 Share Posted January 19, 2012 What did you have to modify to get the new jets to fit into the bonnet or did they just clip in,did you get from honda,how much were they do you have a part number Quote Link to comment Share on other sites More sharing options...
ryan.. Posted January 19, 2012 Share Posted January 19, 2012 i got some from ebay for a citroen c2 iirc. Nice mist, work much better than the honda ones Quote Link to comment Share on other sites More sharing options...
