vincesv650 Posted January 29, 2012 Share Posted January 29, 2012 hi thier i was going to buy a civic vti-s and when i hit the vtec their was a little puff of smoke came out the back and was wondering should i be concerned ???cheers vince Quote Link to comment Share on other sites More sharing options...
knight Posted January 29, 2012 Share Posted January 29, 2012 white or blue smoke??? Quote Link to comment Share on other sites More sharing options...
johngreen537 Posted January 29, 2012 Share Posted January 29, 2012 Blue smoke in vtec, indicates either, a little bit too much oil (not great really) or valve stem seals are worn (Again, not good)TBH, I'd be walking, the stem seals job will set you back a good few hundred quid, of it's overfilled to the point of blue smoke puffing, then it's not been carefully looked after. Quote Link to comment Share on other sites More sharing options...
vincesv650 Posted January 29, 2012 Author Share Posted January 29, 2012 It's looks little blue in it Quote Link to comment Share on other sites More sharing options...
johngreen537 Posted January 30, 2012 Share Posted January 30, 2012 Could be 'normal' I suppose if it's got a decat.....Otherwise, I'd be looking to get it VERY cheap, or walking. Quote Link to comment Share on other sites More sharing options...
knight Posted January 30, 2012 Share Posted January 30, 2012 johngreen537 said: Could be 'normal' I suppose if it's got a decat.....Otherwise, I'd be looking to get it VERY cheap, or walking. Really Quote Link to comment Share on other sites More sharing options...
johngreen537 Posted January 30, 2012 Share Posted January 30, 2012 Not uncommon with decat's mate, given Honda's burn oil in VTEC, the cat normally dissipates a tiny amount when it's burned off.I'd blip the throttle at standstill, watch for small puffs then. If it puffs oil then, could be Oil Rings.Either way, just sounds like a poorly looked after car to me. Quote Link to comment Share on other sites More sharing options...
simpo Posted January 30, 2012 Share Posted January 30, 2012 if its smoking already then it is only going to get worse in the long run. wat you really need to know is how much oil it is burning, which you wont know unless you buy it. the thing is you try and find a civic that is 12+ years old that dont smoke abit Quote Link to comment Share on other sites More sharing options...
leejt1979 Posted January 30, 2012 Share Posted January 30, 2012 simpo said: if its smoking already then it is only going to get worse in the long run. wat you really need to know is how much oil it is burning, which you wont know unless you buy it. the thing is you try and find a civic that is 12+ years old that dont smoke abit they are about!! mine has done 127k and does not smoke!! FSH though!! patience is a virtue they say... good luck! Quote Link to comment Share on other sites More sharing options...
vtivtec170 Posted January 31, 2012 Share Posted January 31, 2012 mine doesnt smoke, 4-1 plus de-cat. 118k on the clock and no service history. last service 8k ago and oil still at the same place on the dip-stick, ie no oil used.suggest the op finds another Quote Link to comment Share on other sites More sharing options...
