remove front lights
LStuart06
hi guys i didnt get a service manual with my car and im just wondering if anyone knows how to remover the front headlamps from the car and how can i get in to it to clean the inside of the headlight as it is all clouded inside and dirty.
Pics would be great to explain where all the bolts are thanks
1"£££$££"!!
You need to take the bumper off very easy 2 screws in each wheel arch and there is some 10 mm bolts underneath then you will have full access to the bolts that hold the head lights in. Then you need to heat the seal up that bonds the headlight together
