Axel Stand Placement
ryan..
I've been searching on here and the net and im yet to find any useful info about axel stand placement on the MB Civics.
I've always been under the impression you use parts of the chassis for it but a thread I found shows it using the jacking points :?
Anyone have a definite answer of where to put them?
I've used 'normal' flat/lipped stands with mine, the chassis bars are good for that, or if you're not removing the inner arms, the inner arm mounting. There are loads of places really & the more the better. I always use a block of softwood between jacks/stands too, prevents wrecking the jack points/chassis.
