civicvti Posted April 7, 2012 Author Share Posted April 7, 2012 The bridges I have already made, In fact v tec and iab work perfectly, also with the light turned yellow. Quote Link to comment Share on other sites More sharing options...
weetec Posted April 7, 2012 Share Posted April 7, 2012 dont forget the code 22 fix...knock sensor..... scott at h-tune has this info... Quote Link to comment Share on other sites More sharing options...
civicvti Posted April 8, 2012 Author Share Posted April 8, 2012 From what I understand, the B18 C4 has not knock sensor, rather than eliminate it by ECU it is not possible to mount and connect a to ECU? Quote Link to comment Share on other sites More sharing options...
civicturbo79 Posted April 8, 2012 Share Posted April 8, 2012 The p72 has knock sensor and the mb6 does not and the p72 has a oil pressure switch and the mb6 not both of these will put the light on , if you get the ecu chipped you can get all this sorted plus bridging some wires . the p72 map makes no more power than the standard p9k map so unless you are going for a custom map there is no point ,Rich. Quote Link to comment Share on other sites More sharing options...
