NIKH25 Posted February 3, 2013 Share Posted February 3, 2013 Just to double check because I don't want any surprises, MG ZS front arb will fit MB3 right ? I plan on buying one and selling my current mb6 arb.Also I'm wondering why mb2/3 front arb has the same better designed droplinks as the zs but the thicker mb6 arb has different worse design Don't see why not, I remember somebody fitted one to an MB6 so should be fine. Quote Link to comment Share on other sites More sharing options...
jasons Posted February 4, 2013 Share Posted February 4, 2013 I've been reading the MG forum recently and came up with this:"While you are swapping the struts over your benefit from swapping the front upper suspension arms from left to right to give you more negitive castor and camber which make your steering respose alot sharper. This is what the ZS has, just come with an 'MG' sticker on them and part numbers changed but the ZS upper legs over the 400/45 is just left for right and right for left"I don't what what that means but have somebody tried it ?EDIT: Something's wrong I can see noodels posted but his post can't be seen I wrote that.the upper arm that has the 'l' on it thats meant to be fitted to the left hand side of the car (passenger/ns) fit to the right (drivers) instead, this will increase castor - not camber.put the left and right arms one above the other and it will all become clear. Quote Link to comment Share on other sites More sharing options...
EmZvr Posted February 4, 2013 Share Posted February 4, 2013 Thanks for the info It's on my to do list but I'm dealing with exams now. I also think that this mod can drop the front a little because of the increased positive castor. Quote Link to comment Share on other sites More sharing options...
vti_786 Posted February 4, 2013 Share Posted February 4, 2013 slightly off topic, but was wanting to know what the original Front ARb diameter was for an MB4(think it would be same as MB3), I'm wanting to get some poly d bushes.thanks Quote Link to comment Share on other sites More sharing options...
EmZvr Posted February 4, 2013 Share Posted February 4, 2013 I'm sorry mate, my stock MB3 arb is long gone and I didn't meassure it. I think it's 18mm but no sure. You have to meassure it to have 100% certain info. Quote Link to comment Share on other sites More sharing options...
EmZvr Posted March 29, 2013 Share Posted March 29, 2013 I have a question again I ordered MG ZS 180 front arb. Can anyone confirm it's the same size as MB6 ? Because my research shows MB6 - 26mm, ZS180 - 24mm And if that's the case which would be better ? Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted March 30, 2013 Share Posted March 30, 2013 I thought they were the same but thicker is always better. Quote Link to comment Share on other sites More sharing options...
EmZvr Posted March 30, 2013 Share Posted March 30, 2013 I thought they were the same but thicker is always better. I really hope they are if not.. again some money wasted Quote Link to comment Share on other sites More sharing options...
